Señores y señoras aquí tenemos al S60 Polestar con 508cv.
Datos técnicos:
Performance
0-100 km/h 3.9s
Top speed more than 300km/h
Engine
Volvo T6 inline six (B6304T4)
508 hp @ 6500rpm
575Nm @ 5500rpm
Max rpm: 7100
Modified cylinder head and combustion chambers
Modified inlet manifold and air intake
Special manufactured conrods
Garret 3171 turbo
Ferrita 3.5” stainless steel exhaust system
Drive train
Reinforced M66C (close ratio) manual 6-speed gear box.
Haldex E-LSD in rear
Haldex Gen4 XWD
Chassis
Tires 265/30R19
Rims Polestar 9,5X19”
Chassis lowered 30mm
Öhlins 3- way shock absorbers
Reinforced anti-roll bar front and rear
Track width increased 20 mm front and 40 mm rear
Polestar-tuned EHPAS steering
Stabilising X- members, front and rear.
Modified control-arms with uniballs front and rear.
Reinforced bushings in sub-frame and control-arms
Modified engine mounts
Weight
Total weight 1640kg and optimized weight distribution
Brakes
Front Polestar-Brembo 6 piston calipers, 380 mm ventilated discs
Rear Polestar-Volvo calipers, 302 mm ventilated discs
Brake cooling air intakes from front
Aerodynamics
Based on tests in Volvo’s wind-tunnel
Lowered front splitter and larger rear spoiler to reduce high speed lift
Carbon fiber diffusor
Body 20 mm widened front and rear
Interior
Polestar designed seats with increased support. Alcantara on all functional areas steering wheel, gear knob, and seats to ensure maximum grip.
Centre console lowered for optimised gear-lever ergonomics.
Aquí las fotos:
Saludos!!
Datos técnicos:
Performance
0-100 km/h 3.9s
Engine
508 hp @ 6500rpm
575Nm @ 5500rpm
Max rpm: 7100
Garret 3171 turbo
Drive train
Haldex Gen4 XWD
Chassis
Tires 265/30R19
Weight
Brakes
Aerodynamics
Interior
Aquí las fotos:
Saludos!!
