a...pues me da el fallo de señal de MAF (121) y este otro (433)...en el pin A2.Entonces no entiendo con mi listado,porque aqui ahora mismo en el A2 no veo otro 433.
What the codes mean:
A1: Transmission
111 No faults found
112 Solenoid S1 short circuit to battery voltage
113 Transmission control module (TCM) fault
114 Program selector open circuit or short circuit to supply
121 Solenoid S1 short circuit to ground or control module fault
122 Solenoid S1 open circuit
123 Solenoid STH short circuit to battery voltage
124 Mode selector faulty or short circuit to ground
131 Solenoid STH open/short circuit or control module fault
132 Transmission control module(TCM) fault
134 Faulty load signal from ignition control module
141 Oil temperature sensor short circuit to ground
142 Oil temperature sensor open circuit
143 Kickdown switch faulty or short to ground
211 Transmission control module (TCM) fault
212 S2 solenoid short circuit to battery
213 Throttle position (TPS) signal too high
221 S2 solenoid short circuit to ground or control module fault
222 S2 solenoid open circuit
223 Throttle position (TPS) sensor signal too low
231 Throttle position (TPS) sensor sporadic
232 Speedometer signal missing
233 Incorrect speedometer signal
235 High Oil temperature
245 Open or short in Torque limiting circuit
311 RPM signal from transmission missing
312 RPM signal from transmission faulty
313 Faulty signal from gear position sensor (PNP)
321 Shift time too long
322 Incorrect gear ratio
323 Lock up slips or is not engaged
331 Short circuit to battery in SL circuit
332 SL solenoid open or control module fault
333 SL solenoid short or control module fault
A2: Fuel System
111 No faults detected
112 Fault in ECM
113 Short term fuel mixture too weak
115 Injector 1
121 MAF sensor signal
123 ECT signal
125 Injector 2
131 RPM sensor signal missing
132 Battery voltage
135 Injector 3
143 Front knock sensor signal
145 Injector 4
153;
153 Rear HO2S signal
154 EGR system leakage
155 Injector 5
212 Front HO2S signal
214 RPM sensor signal sporadic
223 IAC valve opening signal
225 A/C pressure sensor signal
231 Long term fuel trim, part load
232 Long term fuel trim, idling
233 Long term idle air trim
241 EGR system flow malfunction
245 IAC valve closing signal
311 VSS signal
314 CMP sensor signal
315 EVAP system
325 Memory failure
335 Request for MIL lighting from TCM
411 TP sensor signal
413 EGR temp sensor signal
414 Boost pressure regulation
416 Boost pressure reduction from TCM
425 Rear HO2S sensor control faulty
432 Temperature warning level 1
433 Rear knock sensor signal
435;
435 Front HO2S slow response
436,
436 Rear HO2S compensation
443 Three way cat. Efficiency
444 Acceleration signal
451 Misfire cylinder 1
452 Misfire cylinder 2
453 Misfire cylinder 3
454 Misfire cylinder 4
455 Misfire cylinder 5
512 Short term fuel trim (integrator), lower limit
513 Temperature warning level 2
514 Engine cooling fan low speed signal
521 521 Front HO2S Preheating
522;
522 Rear HO2S Preheating
531 Power stage group A
532 Power stage group B
533 Power stage group C
534 Power stage group D
535 TC control valve signal
541 EVAP valve signal
542 Misfire more than one cylinder
543 Misfire at least one cylinder
544 Misfire more than one cylinder, three way cat damage
545 Misfire at least one cylinder, three way cat damage
551 Misfire cylinder 1, three way cat damage
552 Misfire cylinder 2, three way cat damage
553 Misfire cylinder 3, three way cat damage
554 Misfire cylinder 4, three way cat damage
555 Misfire cylinder 5, three way cat damage
A3: ABS
111 No DTC set
121 Left front wheel sensor, faulty signal <40 km/h
122 Right front wheel sensor, faulty signal <40 km/h
123 Left rear wheel sensor, faulty signal <40 km/h
124 Right rear wheel sensor, faulty signal <40 km/h
125 Signal faulty from at least one wheel sensor for a long period
135 Control Module faulty
141 Faulty pedal sensor, shorted to ground or supply
142 Faulty brake pedal switch, open or short
143 Control module faulty
144 Brake discs overheated
151 Left front wheel sensor, open/short to battery
152 Right front wheel sensor, open/short to battery
155 Rear axle sensor open/short to battery
211 Left front wheel sensor, not signal on moving off
212 Right front wheel sensor, no signal on moving off
213 Left rear wheel sensor, no signal on moving off
214 Right rear wheel sensor, no signal on moving off
215 Valve relay, open/short
221 Left front wheel sensor, ABS operation signal missing
222 Right front wheel sensor, ABS operation signal missing
223 Left rear wheel sensor, ABS operation signal missing
224 Right rear wheel sensor, ABS operation signal missing
231 Left front wheel sensor, signal missing
232 Right front wheel sensor, signal missing
235 Rear axle sensor, signal missing
311 Left front wheel sensor, open/short
312 Right front wheel sensor. open/short
313 Left rear wheel sensor, open/short
314 Right rear wheel sensor, open/short
321 Left front wheel sensor, irregular >40 km/h
322 Right front wheel sensor, irregular >40 km/h
323 Left rear wheel sensor, irregular >40 km/h
324 Right rear wheel sensor, irregular >40 km/h
411 Left front wheel inlet valve, open/short
412 Left front wheel return valve, open/short
413 Right front wheel inlet valve, open/short
414 Right front wheel return valve, open/short
415 Rear valve open/short
421 Rear wheel inlet valve circuit, open/short
422 Rear wheel return valve circuit, open/short
423 Traction control system valve, open/short
424 Pressure switch for TRACS, faulty or short circuit
441 Control module faulty
442 Pump pressure low
443 Pump motor, electrical or mechanical fault
444 No power supply to valves in hydraulic unit
A6: Ignition System (On some cars, this may not respond. See A2)
111 No DTC set
112 Control Module fault
123 Engine Coolant Temperature Sensor (ECT) from Control module missing or faulty
131 Engine speed (RPM) sensor signal missing
142 Control Module Fault
143 Knock sensor (KS) missing or faulty
144 Ignition control module load signal missing
154 EGR system flow too high in system
214 Engine speed (RPM) sensor signal missing sporadically
224 Engine Coolant Temperature sensor (ECT) signal missing or faulty
234 Throttle Position (TPS) signal missing at idle
241 EGR system flow too low in system
243 Throttle Position sensor (TPS) signal missing at idle
311 Vehicle speed signal missing or faulty
314 Camshaft Position sensor (CMP) signal missing or faulty
324 Camshaft Position sensor (CMP) signal missing sporadically
411 Throttle position sensor (TPS) signal from fuel injection system missing or faulty
413 EGR temperature sensor signal faulty
432 Control module box temperature too high level 1
433 Knock sensor (KS) signal missing or faulty
513 Control module box temperature too high, level 2
A7: Instrument Cluster
112 Fuel gauge short circuit
113 Fuel gauge open circuit
121 Temp. sensor interval too short
122 Temp. sensor interval too long
123 Digital output 48 pulse short circuit to supply
131 Digital output 12 pulse short circuit to supply
132 No RPM sensor signal
133 Tank signal to trip computer short to supply
221 Speed signal/signal absent
B1: Electronic Climate Control
111 No fault
121 Outside temperature sensor shorted to ground
122 Outside temperature sensor open circuit or shorted to 12 volts
123 Driver's side interior temperature sensor shorted to ground
124 Driver's side interior temperature sensor open circuit or shorted to 12 volts
125 Passenger's side interior temperature sensor shorted to ground(earth)
126 Passenger's side interior temperature sensor open circuit or shorted to 12 volts
131 Driver's side air duct temperature sensor shorted to ground(earth)
132 Driver's side air duct temperature sensor open circuit or shorted to 12 volts
133 Passenger's side air duct temperature sensor shorted to ground(earth)
134 Passenger's side air duct temperature sensor open circuit or shorted to 12 volts
135 No signal from engine coolant temperature sensor
141 Faulty signal from driver's side temperature selector switch
143 Faulty signal from passenger's side temperature selector switch
145 Faulty signal from function selector switch
151 Signal from fan speed sensor missing or too high
152 Signal from fan speed sensor shorted to earth
211 Driver's side damper motor position sensor open circuit or shorted to 12 volts
212 Driver's side damper motor position sensor shorted to earth
221 Passenger's side damper motor position sensor open circuit or shorted to 12 volts
222 Passenger's side damper motor position sensor shorted to earth
231 Ventilation damper motor position sensor open circuit or shorted to 12 volts
232 Ventilation damper motor position sensor shorted to earth
233 Floor/defrost damper motor position sensor open circuit or shorted to 12 volts
234 Floor/defrost damper motor position sensor shorted to earth
235 Recirculation damper motor position sensor open circuit or shorted to 12 volts
236 Recirculation damper motor position sensor shorted to earth
311 Driver's side damper motor shorted to earth or shorted to 12 volts
312 Passenger's side damper motor shorted to earth or shorted to 12 volts
313 Ventilation damper motor shorted to earth or shorted to 12 volts
314 Floor/defrost damper motor shorted to earth or shorted to 12 volts
315 Recirculation damper motor shorted to earth or shorted to 12 volts
321 Driver's side damper motor active too long
322 Passenger's side damper motor active too long
323 Ventilation damper motor active too long
324 Floor/defrost damper motor active too long
325 Recirculation damper motor active too long
411 Blower fan seized or drawing excessive current
412 Driver's side interior temperature sensor inlet fan shorted to earth
413 No control voltage at driver's side interior temperature sensor inlet fan
414 Driver's side interior temperature sensor inlet fan seized
415 Passenger's side interior temperature sensor inlet fan shorted to earth
416 No control voltage at passenger's side interior temperature sensor inlet fan
417 Passenger's side interior temperature inlet fan seized
418 No control signal to blower fan power stage
419 Faulty diagnostic signal from blower fan power stage
420 ECU fault in program memory
511 Damper motor limit position self-adjustment not carried out
B2: Cruise Control
112 Abnormal speed signal
122 Speed has not exceeded 22mph or no speed signal
211 Control module malfunction
212 Malfunction in the circuit to the vacuum pump or regulator
B5: SRS
111 No fault detected
112 Sensor module fault
127 SRS lamp open/short circuit
211 Drivers airbag short circuit
212 Drivers airbag open circuit
213 Drivers airbag short circuit to ground
214 Drivers airbag short circuit to supply
221 Passenger airbag short circuit
222 Passenger airbag open circuit
223 Passenger airbag short circuit to ground
224 Passenger airbag short circuit to supply
231 Left belt tensioner short circuit
232 Left belt tensioner open circuit
233 Left belt tensioner short circuit to ground
234 Left belt tensioner short circuit to supply
241 Right belt tensioner short circuit
242 Right belt tensioner open circuit
243 Right belt tensioner short circuit to ground
244 Right belt tensioner short circuit to supply
B6: Power Seat
112 Position sensor for motor. Signal missing or defective
114 Motor 4. Open circuit
121 Position sensor for motor 2. Signal missing or defective
123 Motor 1. Motor running, even though its button is not being pushed
131 Motor 2. Motor running, even though its button is not being pushed
132 Motor 3. Motor running, even though its button is not being pushed
133 Motor 4. Motor running, even though its button is not being pushed
143 Motor 1. The motor is turning in wrong direction
144 Motor 2. The motor is turning in wrong direction
211 Position sensor for motor 4. Signal missing or defective
214 Motor 3. The motor is turning in wrong direction
224 Motor 4. The motor is turning in wrong direction
321 Fault in stored memory position 3
322 Fault in stored memory position 2
323 Fault in stored memory position 1
331 Motor 1 break in lead
332 Motor 2 break in lead
333 Motor 3 break in lead
414 Limit position. Incorrect calibration
1-2-21-2-2 Position sensor for motor 3, signal absent or faulty
