Cómo resetear el indicador de servicio
14 Jul 2010
375
60
Este es un tema recurrente que siempre nos encontramos cada vez que nos ocurre y..... nunca nos acordamos de cómo se hace.
Pues aquí dejo una pequeña guía que nos ilustra sobre cómo resetear el indicador de servicio de nuestros Volvos:
Resetting the Service reminder indicator (SRI), model years -2001
The service reminder indicator (SRI) informs the driver that it is time for the car to be serviced. The lamp remains lit for 120 seconds when the ignition is switched on.
Proceed as follows to reset the service reminder indicator (SRI):
1) Ignition position I
2) Press and hold in the reset button for the trip odometer
3) Ignition position II
4) The service reminder indicator (SRI) starts flashing when the reset button for the trip odometer has been pressed for 10 seconds
5) Release the reset button for the trip odometer within 5 seconds. The instrument gives an audible signal when resetting has succeeded.
Note! If the trip meter reset button is not released within 5 seconds the indicator is not reset. However the indicator will stop flashing.
Resetting the service reminder indicator (SRI), model years 2002-
3) Ignition position II.
Note! Turn the key to position II within 2 seconds.
5) Hold the reset button for the trip meter pressed in until the original value has been reset.
Note! For all vehicles from the 2003 model year a general yellow lamp will light when the reset button must be released.
Release the reset button for the trip odometer within 4 seconds. The instrument gives an audible signal when resetting has succeeded
If the trip meter is already reset the reset button should be held in for a minimum of 10 seconds and a maximum of 14 seconds.
Note! If the reset button for the trip odometer is not released within 4 seconds, the service reminder indicator (SRI) is not reset.
