Resultados 1 al 10 de 22
Cable diagnosis Volvo 99 euros, ahora 80 euros
Volvo cable de diagnosis. valido para: 800 Series C70 S40 V40 S70 V70 900 series ...
    18 sep, 08
    14
    Predeterminado Cable diagnosis Volvo 99 euros, ahora 80 euros
    valido para:
    800 Series
    C70
    S40
    V40
    S70
    V70
    900 series
    S90
    V90
    airbag, abs, codigos de error, inmobilizador, abs, navegador, climatizador...
    Interesados consultar al seis, cinco, 2176046
    25 abr, 07
    624
    Predeterminado Re: Cable diagnosis Volvo 99 euros
    Mediante que software funciona? es por puerto com o USB?
    19 ago, 08
    156
    Si la foto es real, es por puerto com.
    Ahora solo queda que nos diga si el software con el que funciona.
    18 sep, 08
    14
    el software es el Fcr
    25 abr, 07
    624
    Permite configurar algun parametro, o solo consulta? que permite hacer ese cable?
    18 sep, 08
    14
    Cita Iniciado por forcead
    te pongo las carateristica, estan en ingles!!:
    What is Volvo FCR?
    Volvo FCR is a Windows-based Diagnostic Software for Volvo that emulates the functions of the dealers' very expensive proprietary scan tools. As the first aftermarket Volvo-Tool, it has the following features:
    Volvo control module coverage includes:
    Engine - Petrol and Diesel
    ABS
    Automatic transmission
    SRS - airbag and other protection systems
    Driver and passenger seat memories
    Instruments, including service light reset
    Climate control - air conditioning
    Immobilizer
    Alarm
    Road traffic information
    Additional heater
    How to Use?
    For laptops and PCs, download the shareware 1.3
    Run it and follow the prompts to allow it to install itself.
    Note: You must install volvo FCR on your PC's hard disk -- it will not work properly if you try running it directly from a floppy or CD. However, you can use a floppy or CD to move the distribution file from a PC with internet access to another PC that does not have internet access.
    Connect the interface between the computer and the car by plugging one end of the interface into a Serial (RS232) (or USB port ) on your PC and the other end directly into the OBD-II port present passenger vehicles.
    Turn the car's ignition switch ON. No need to start the engine.
    Start the Volvo program,
    Now it works. Make sure the software can reliably access all the control modules that it should in your car.
    What are the system and computer requirements?
    A PC running Windows: It is recommended to use at least a Pentium-100 (or AMD equivalent) with 16MB of RAM and Windows 95 or newer. Volvo FCR may work on some lesser PC's, but anything less than the above recommendation is unsupported. Windows 95, 98, ME, NT4, 2000, and XP are all fine. Available disk-space is a total non-issue, Volvo FCR requires less than 1 MB.
    25 abr, 07
    624
    He conseguido el software completo y solo es consulta, me pregunto si valdria el cable para el Vadis, de ser asi si que estaria interesado
    18 sep, 08
    14
    no se si vale para vadis.
    18 sep, 08
    14
    Lo dejo en 90 euros.
    saludos.
    18 sep, 08
    14
    Predeterminado Re: Cable diagnosis Volvo 99 euros, ahora 90 euros
    up!!!!!!!!!!!!!!!!!
  1. Pe ahora 31300 euros
    Por MrMercury en el foro VOLVO XC60 (2008-2017)
    Último mensaje: 20/10/2016, 18:09
  2. Que cable diagnosis comprar Autocom o volvo dice?
    Por rizosu en el foro Area Tecnica Volvo
    Último mensaje: 28/09/2014, 22:07
  3. cable diagnosis volvo
    Por fersanz en el foro Foro General Volvo
    Último mensaje: 04/01/2014, 12:12
  4. cable diagnosis
    Por jomasur en el foro Compra Volvo
    Último mensaje: 16/07/2010, 20:14
