Resultados 1 al 5 de 5
home cinema Harman Kardon AVR3000+Harman Kardon DVD22
    Avatar de xbeltran
    05 may, 09
    viladecans
    2,059
    volvo s60 d5 optima
    Predeterminado home cinema Harman Kardon AVR3000+Harman Kardon DVD22
    se vende amplificador Harman kardon de home cinema modelo AVR 3000, y DVD 22 de la misma marca, hacen conjunto y se pueden controlar desde un mismo mandoa distancia.
    Incluye los dos mandos a distancia de los dos aparatos y los libros de instruciones de los aparatos
    aqui os dejo una fotos y las caracteristicas de los aparatos.
    Specifications
    Audio
    Stereo ModeContinuous Average Power (FTC) Per Channel:* * * * * * * * 50 Watts per channel, 20Hz - 20kHz, @ <0.07% THD, both channels driven into 8 ohms
    Five-Channel Surround Modes, Power Per Individual Channel:* * * * * * * *
    Front L & R Channels:* * * * * * * * 40 Watts per channel @ <0.07% THD, 20Hz - 20kHz into 8 ohms
    Center Channel:* * * * * * * * 40 Watts @ <0.07% THD, 20Hz - 20kHz into 8 ohms
    Surround Channels:* * * * * * * * 40 Watts per channel @ <0.07% THD, 20Hz - 20kHz into 8 ohms
    Input Sensitivity/Impedance Linear (High Level):* * * * * * * * 200mV/47k Ohms
    Signal-to-Noise Ratio (IHF-A):* * * * * * * * 95dB
    Surround System Adjacent Channel Separation:* * * * * * * *
    Analog Decoding (Pro Logic®, etc.):* * * * * * * * 40dB
    Dolby® Digital (AC-3®):* * * * * * * * 55dB
    DTS:* * * * * * * * 55dB
    Frequency Response at 1W (+0dB, -3dB):* * * * * * * * 10Hz - 100kHz
    High Instantaneous Current Capability (HCC):* * * * * * * * ±25 Amps
    Transient Intermodulation Distortion (TIM):* * * * * * * * Unmeasurable
    Rise Time:* * * * * * * * 16 µsec
    Slew Rate:* * * * * * * * 40V/µsec
    FM Tuner
    Frequency Range:* * * * * * * * 87.5 - 108.0MHz
    Usable Sensitivity:* * * * * * * * IHF 1.3 µV/13.2dBf
    Signal-to-Noise Ratio (Mono/Stereo):* * * * * * * * 70dB/68dB
    Distortion (Mono/Stereo):* * * * * * * * 0.2%/0.3%
    Stereo Separation:* * * * * * * * 40dB @ 1kHz
    Selectivity:* * * * * * * * ±400kHz, 70dB
    Image Rejection:* * * * * * * * 80dB
    IF Rejection:* * * * * * * * 90dB
    Tuner Output Level:* * * * * * * * 1kHz, ±75kHz Dev 500mV
    AM Tuner
    Frequency Range:* * * * * * * * 520 - 1710kHz
    Signal-to-Noise Ratio:* * * * * * * * 45dB
    Usable Sensitivity:* * * * * * * * Loop 500µV
    Distortion:* * * * * * * * 1kHz, 50% Mod 0.8%
    Selectivity:* * * * * * * * ±10kHz, 30dB
    Video
    -:* * * * * * * * PAL/NTSC
    Input Level/Impedance:* * * * * * * * 1Vp-p/75 Ohms
    Output Level/Impedance:* * * * * * * * 1Vp-p/75 Ohms
    Video Frequency Response:* * * * * * * * 10Hz - 8MHz (-3dB)
    General
    Power Requirement:* * * * * * * * AC 220-240V/60Hz
    Power Consumption:* * * * * * * * 72 Watts idle, 580 Watts maximum (2 channels driven)
    Dimensions (H x W x D):* * * * * * * * 165mm x 440mm x 435mm
    Weight:* * * * * * * * 14.1kg
    todo el conjunto 400 euros mas gastos de envio
    tener en cuenta que estamos hablando de alta fidelidad no de un home cinema cualquiera.
    el preciodel dvd solamente es de 300 euros en tienda.
    y el del amplificador de casi 700
    17 sep, 10
    Algeciras
    757
    Predeterminado Re: home cinema Harman Kardon AVR3000+Harman Kardon DVD22
    Buen equipo y a un precio aun mejor. que alguien lo recoja y de bue uso de el. saludos
    Avatar de xbeltran
    05 may, 09
    viladecans
    2,059
    volvo s60 d5 optima
    nadie se anima el precio podriamos negociarlo.
    France
    Avatar de gabach
    09 jun, 08
    BCN city
    8,452
    buenas!
    tengo algunas cosas en venta en casa, no se si estarías interesado por un cambio por piezas... si quieres miro lo que tengo que no este en la sección de venta del foro y me dices si te interesa...
    Avatar de xbeltran
    05 may, 09
    viladecans
    2,059
    volvo s60 d5 optima
    dime lo que tienes y hablamos
  1. HARMAN KARDON 9" con SUBWOOFER
    Por Terodac en el foro VOLVO XC60 (SPA: 2017 - )
    Último mensaje: 22/03/2018, 09:34
  2. HARMAN KARDON
    Por V40D3R17 en el foro Audio y multimedia Volvo
    Último mensaje: 16/06/2017, 16:46
  3. Home cinema.
    Por Joan_c30 en el foro Off-Topic General
    Respuestas: 16
    Último mensaje: 27/08/2012, 16:15
  4. Home Cinema Inalambrico
    Por gabach en el foro Off-Topic General
    Último mensaje: 05/08/2010, 18:15
  5. Ipod a traves de Harman/Kardon
    Por unaele en el foro VOLVO XC90 (2002-2015)
    Respuestas: 24
    Último mensaje: 24/09/2008, 18:13
