Resultados 1 al 3 de 3
SC 813 ARROJA UN ERROR
ESTIMADOS AMIGOS !! : ME DEVOLVIERON POR FIN (UN TALLER DE "REPARACIONES") UNA RADIO SC ...
    Chile
    Avatar de Don Mono
    28 dic, 07
    1,710
    Predeterminado SC 813 ARROJA UN ERROR
    ME DEVOLVIERON POR FIN (UN TALLER DE "REPARACIONES") UNA RADIO SC 813 DE MI V40 1999 PERO CUANDO LA CONECTE ME DICE "OFF" NI SIQUIERA ME PIDE EL CODIGO
    LA VERDAD ES Q EL AUTO QUE LO COMPRE DE SEGUNDA MANO, NO VENIA CON ESA RADIO Y LOGRE QUE ME LA DEVOLVIERAN EN EL SERVICIO TECNICO.... PERO NO SE SI FUNCIONA O NO. .. SOLO LAPUEDO PRENDER Y ME DICE "OFF". . .
    QUE LE PASA A LA RADIO? ESTA MALA , ESTA MUERTA O QUE?
    ESPERO ME AYUDEN POR FAVOR
    DON MONO VOLVERO DESDE CHILE
    SALU2
    18 ene, 07
    28
    Predeterminado Re: SC 813 ARROJA UN ERROR
    hola ...me temo que no vas a poder hacerle nada....las radios de los coches originales ...si te equivocas introduciendole el pin 3 veces (erroneo) se bloquean permanente. es decir solo te servira de respuestos ..o a la basura .
    un saludo
    25 abr, 07
    624
    Radio Says "OFF"
    Most Volvos have a radio code to prevent theft. This code usually is a 4 digit code that should be stored in a safe place at all times! When the battery dies you will need this code to make the radio play again, but sometimes the radio will go into lock out mode and say "OFF." The only way to get by this so that "CODE" is displayed again, is to turn your switch to the 2nd position on the key switch and let set for 2-3 hours until it comes up.
    Once it has been reset you should be able to enter the code into the radio and should work. If you enter the code incorrectly it will say "RPT" and you get another chance to enter it in, but if you enter it incorrectly three times it will go back into lock-out mode and say "OFF" and you will have to restart the entire process.
    Viene a decir que dejes el contacto 2 puesto 3 horas y que se resetea la radio, luego tienes que meter el codigo bueno, y que tienes 3 intentos, si fallas tienes que volver a resetear la radio
  1. Error 019
    Por jcsca en el foro Area Tecnica Volvo
    Último mensaje: 18/12/2015, 00:12
  2. Error 019
    Por jcsca en el foro Foro General Volvo
    Último mensaje: 07/12/2015, 19:21
  3. Error SRS, error ABS, y deja de funcionar todo el sistemas electrico
    Por Narf2000 en el foro VOLVO XC90 (2002-2015)
    Último mensaje: 07/07/2015, 19:24
  4. Mensaje error
    Por antonioluis en el foro VOLVO S60/V60/S70/V70/
    Último mensaje: 08/08/2014, 15:20
  5. error
    Por penta en el foro VOLVO 200/300/400/700/800/900/S90/V90
    Último mensaje: 24/11/2009, 13:23
