Resultados 1 al 8 de 8
Power Beauty Soul
    17 nov, 06
    220
    Predeterminado Power Beauty Soul
    FRENOS GALFER 6 PISTONES
    REPARTIDOR VARIABLE DE FRENADA TREN TRASERO INDIVIDUAL
    CAIDAS NEGATIVAS TREN DELANTERO
    1º AVANCE INTERIOR TREN TRASERO
    [img width=666 height=500]http://img259.imageshack.us/img259/2812/10102007039qh8.jpg[/img]
    DOWNPIPE 4" ARTESANAL
    ESCAPE 3" ARTESANAL
    [img width=666 height=500]http://img160.imageshack.us/img160/181/13112007123fs8.jpg[/img]
    TURBO KKK K29 CERAMICO +2bar
    VALVULA BLINDADA SOLDADA
    [img width=666 height=500]http://img211.imageshack.us/img211/8227/12112007119ug7.jpg[/img]
    VALVULAS DE SODIO ASIENTO A 30º
    CULATA 33CM3 ARTESANAL
    DOBLE BOMBA GASOLINA ORIGEN LAMBORBGHINI
    BUJIAS DE PLATINO DE CUELLO CORTO
    BOBINA MULTIENCENDIDO MSD IGNITION
    CABLES MAGNECOR 9.5MM
    DOBLE RAMPA DE INYECCION
    INYECTORES "NARANJAS" 500CC3
    INYECCION ADDICIONAL METHANOL
    TUBERIA ADMISION 3" ARTESANAL
    INTERCOOLER REFRIGERADO 3" ARTESANAL
    SISTEMA DE INYECCION DE AGUA AQUAMIST
    COLECTOR DE ESCAPE ARTESANAL
    COLECTOR DE ADMISION VARIABLE
    ARBOLES DE LEVAS SUPER GTR
    [img width=625 height=500]http://img528.imageshack.us/img528/9854/imagen006rt1.jpg[/img]
    [img width=700 height=7]http://img528.imageshack.us/img528/9854/imagen006rt1.b05f9ed4f0.jpg[/img]
    [img width=666 height=500]http://img70.imageshack.us/img70/2891/20092007007uh2.jpg[/img]
    [img width=666 height=500]http://img80.imageshack.us/img80/1585/18102007050zk6.jpg[/img]
    [img width=666 height=500]http://img158.imageshack.us/img158/1917/18102007057vm8.jpg[/img]
    [img width=666 height=500]http://img530.imageshack.us/img530/7963/18102007065zu8.jpg[/img]
    [img width=700 height=4]http://img530.imageshack.us/img530/7963/18102007065zu8.b36182dc00.jpg[/img]
    [img width=666 height=500]http://img123.imageshack.us/img123/4853/20092007006al4.jpg[/img]
    [img=http://img123.imageshack.us/img123/1300/20092007007dh0.jpg]http://
    [img width=666 height=500]http://img215.imageshack.us/img215/6526/20102007073ww0.jpg[/img]
    [img width=666 height=500]http://img127.imageshack.us/img127/9426/20102007075as9.jpg[/img]
    BLOQUE 2500CM3
    PISTONES FORJADOS
    BIELAS AH
    MAF VARIABLE
    DOBLE JUNTA DE CULATA
    BOMBA DE ENGRASE 7bares
    CIGUEÑAL ALIGERADO/EQUILIBRADO CONJUNTO GRUPO Y POLEAS
    CREMALLERA DE DIRECCION RAPIDA
    SISTEMA DE CAMBIO QUICKSHIFT
    SEPARADORES DELANTEROS DOBLE CENTRAJE 10MM
    SEPARADORES DOBLE CENTRAJE TRASEROS 20MM
    REFUERZO ESTRUCTURAL TUBULAR ARTESANAL
    BARRA DE TORRETAS VOLVO
    CHASIS ALIGERADO
    MANGITOS SAMCO AGUA
    MANGITOS VENAIR TURBO
    SUSPENSION KONY REGULABLE ARTESANAL
    MUELLES TIPO TREN ARTESANAL
    CAJA DE CAMBIOS M56W AUTOBLOCANTE APR
    REFUEZO SOPORTES DE MOTOR EN ALUMINIO ARTESANALES
    ELECTRONICA DE ORIGEN
    EMBRAGUE CERAMICO
    PLATO Y COLLARIN DE ALTA PRESION
    VOLANTE ALIGERADO
    [img width=666 height=500]http://img99.imageshack.us/img99/760/18102007056mf4.jpg[/img]
    [img width=625 height=500]http://img528.imageshack.us/img528/9927/imagen013md9.jpg[/img]
    [img width=700 height=7]http://img528.imageshack.us/img528/9927/imagen013md9.95fe5c8aae.jpg[/img]
    Potencia ... suficiente
    Diseño de motor, calculos y montaje realizado por:
    - Trompo Racing
    - Turbo Centro
    - Volvo Mania
    240 GLT<br />740 GLE<br />740 Turbo 16v<br />740 Turbo 16v<br />760 Turbo 8v<br />760 GLE<br />780 Bertone<br />850 T-5<br />850 T-5<br />855 R<br />855 T5-R<br />960 2.5 24v<br />960 3.0 24v<br />S40 1.8<br /><br />OLD VOLVOS NEVER DIE, THEY JUST GO FASTER
    Antigua and Barbuda
    Avatar de Señor K
    24 jun, 08
    Tropical Charroland
    8,822
    4
    Un scooter gris
    Predeterminado Re: Power Beauty Soul
    Joder, no tengo palabras
    Esto sí que es preparar un coche de forma "respetable". Esto no es tuneo, esto es arte
    Andorra
    Avatar de JulioXC
    26 nov, 06
    Lleida
    5,362
    XC70II 185 Cv - V50 2,0
    esto a quedado de muerte,sera un misil ,menuda preparacion, el propìetario va a disfutar como un jabato.
    26 nov, 07
    860
    Vaya curro
    17 nov, 06
    220
    Fallos... Estaba mirando los post y se lo dedico a volvo4life[DTR]
    El escape lo tienes demasiado abierto, lo que haría sería dar mas vueltas a la turbina del turbo por dejarla mas libre, y en X tiempo menor de lo normal..griparlo.
    R: La turbina de escape de mi turbo de carreras es de 7 alaves, mientras que la de un turbo convencional es de 11... entiendes la respuesta, no?
    Las bujías de platino son carisimas, no rentabilizan para el trabajo de lo que se haga.
    R: Si aumento la chispa junto con un volumen mayor en la camara y una mezcla muy potente y mantengo una bujia de serie, te garantizo que el motor no llega ni a 1000km.
    La doble rampa de inyección, no se exactamente como es, ¿me podrías hacer una foto?
    R: Te hare la foto, una rampa adiciona que se activa al pasar de 1.4bares.
    Y la tubería de admision artesanal, tampoco se como es, ¿podrías hacerme una foto también?
    R:Fijate que los colectores de admision no son los suyos originales ademas de estar modificados y llevar admision variable.
    El colector de escape tampoco lo veo, ¿me podrías hacer una foto también de ello?
    R: El colector tampoco es el suyo original ademas de que tuve que modificarlo para que todo el flujo de aire coincidiera con la entrada del turbo.
    La doble junta de culata... no se pero lo veo como un error, ya que están las juntas mas expuestas a la presión de explosión y calor, ¿Podría salir afectado?
    R: Juntas de Culatas dobles... juntas de culata de 3.5mm con doble lamina metalica, imagino que las habras visto muchas veces en coches de carreras.
    Bomba de engrase a 7 bares me parece también mucho, cuando creo que lo normal serían a unas 33libras (mas o menos 1 bar y medio a casi 2 bares de presión).
    R: 1bar?...2 bares??Con eso gripas el motor pero antes de llegar al final de la calle.
    Y sobre el sistema de frenos, estaría bien que pusieras una bomba de mayor fuerza hidraulica.
    R: La bomba esta modificada
    También tengo otra duda, el refuerzo de soportes del motor en aluminio artesanal, en las fotos yo lo veo iguales a los de origen y pintados
    R: El taco trasero de la pieza, y el delantero de nylon, lo que ves pintado es la pieza. ademas llevo el inferior en aluminio y una barra inferior en triangulo.
    (Ojo, todo lo que digo es en mi opinión, no hablo con ironías, únicamente por informarme)
    También siento curiosidad con la sonda lambda, al quitar el catalizador, la sonda mandaría a la centralita diferente señal, y todo estaría descontrolado, pero me desconcierta que no tocases la electronica.
    R: Se rige mediante una ley de proporciones.
    Trompo.
    Avatar de volvo4life[DTR]
    26 nov, 06
    4,428
    Volvo 740 TD SW
    Ya decía yo que algo pasaba con la junta,
    Por el resto, muchas gracias por contestarme y corregirme, así aprendo
    Es decir, todo lo que has hecho ronda por los 20.000€ en gastos medios (lo digo por que no lo sé con exactitud), pero la preparación no a sido barata ni mucho menos
    ¿A pisado ya territorio de carreras? Se debe de marcar unas buenas PB's
    Salu2, y de nuevo gracias por las correcciones!!
    V4L-Moderador_A
    Avatar de $UPER
    15 mar, 06
    ALICANTE
    13,447
    Joder no había visto esto hasta hoy!!!!!!!
    Pedazo de Fiera que te has dejado......
    No entiendo ni la mitad de cosas que comentas en cuanto a lo que le has hecho,
    pero me parece un trabajo digno de admiración,
    me figuro que sigue tan bien como el primer dia!!!!!!
    France
    Avatar de gabach
    09 jun, 08
    BCN city
    8,452
    es una pasada esa bestia!!!
    Seremos los suficientemente buenos como para poder disfrutar de mas imágenes, y si posible vídeos?
  1. Encuesta fiabilidad JD POWER
    Por wierner en el foro VOLVO XC60 (2008-2017)
    Último mensaje: 23/02/2017, 23:29
  2. Power On Board
    Por gabach en el foro Tuning Volvo
    Respuestas: 18
    Último mensaje: 17/08/2015, 08:51
  3. 4 llantas +POWER 431
    Por vs40 en el foro Venta Volvo
    Respuestas: 29
    Último mensaje: 03/02/2013, 23:34
  4. Power Balance....
    Por VOLVO_T en el foro Off-Topic General
    Último mensaje: 07/04/2010, 23:55
  5. JD Power 2009
    Por ferod en el foro Foro General Volvo
    Último mensaje: 07/08/2009, 12:18
